Has anyone come up with a good way to change the location of that POS filler that we have for the powersteering pump? I hate having to use a funky funnel in order to circumvent the intercooler lines on the stock SC. I always end up over filling the &#$%ing thing.
Any suggestions?
Thanks
I dont know about moving the fill plug, but if you take the upper Ic tube off you have a lot more room to get down there. At least i do with my 92'.
that seems like a LOT of work to do every time that you have to fill the PS. I just didn't know if there was a newer version of the filler tube that was put on in latter years.
Why do you need to fill it that often? I have not had to add any fluid to mine in years. You must have a leak that needs to be fixed, which may be better and easier than fabbing something to help fill it. Good luck
Was just curious as to if they found a better location for the fill tube. I'm doing a MAJOR overhaul, and didn't know if they had resolved that issue.
