My power steering is leaking I think. The fluid level drops from max to mix in about 10 miles. Has anyone else had problems of this nature? Do you think its a leak. If so how Much approximately?
yup.. check the rubber elbo 90/90 elbo right behind the plastic part of the pump... it corrodes when it gets old and cracks.. if thats it just the metal line right before the rubber part then buy a pice of hoes that size and use a hose clamp on each end to fix it.
dont let it run down... i did... i had to replace my pump... and my rack :(
