Best advice I can give is remove the oil filter and power steering pump for easy access to the high pressure line at the rack. Stubby wrenches will also be useful.
I got the power steering pump off but I cant disconnect the hose from either the pump or the rack ! I started to strip the nut on the pump so I called it quits foe today .
Does the thread go backwards on the hose or do I need a special wrench ?
What size wrench ?
I borrowed a flare nut wrench and that helped with the pump side now I only need to remove the rack side and this bithc is not moving I'm afraid of ruining the rack side fitting .
Did you use a flare-nut wrench? It's leaking, so the nut is soaked, and a normal wrench won't hold strong and may slip, Possibly that's why it started to strip.
I cant use the flare nut wrench because it wont go over the nut since its attached to the other rack end .
sorry I can't comment on what size, but I need to do the same because mine is leaking too.
I don't know for sure if there is room for this but...
if there is, cut the metal line above the nut. You can now slide a 6 point socket or wrench over it that won't slip.
You need to remove the powers steering pump& hose's , the bracket ,oils filter undo the lower water hose unbolt the rack move it around till you see the nut .
Then you need to get a wrench on the rack side of the hose nut then wrench the nut on the power steering pump side and undo .
This is a pain in the ass job I now have a new leak from the rack side !!
I called it quits for now and I might start saving for a newer car since I have this new leak now .
Is 33 to young to start hating working on cars ?
I agree, when i did mine, all i could do for the day was curse the damn engineers that designed this setup. It's gotta be the worse damn power steering hose i've ever replaced.
I have to re -do the whole job now but I'm going to take my time maybe work on it over a few weekends .
Looks like the rack might have to come down but not sure yet , I'm hoping its just an o ring that needs to be replaced .
Awww man, that sucks. Last time I did a rack install in a 93 cougar I wound up bending the tubes that come out of the rack and meet the hoses The tubes no longer were sealing inside the nuts. I had to replace the nuts and push in a new tube (relatively cheap parts from ford). That's what I get for thinking I found an easy way to change it and not just doing it the sucky way like i do on my 94. On 3.8, you can just reach down by the power dist box to unhook the lines from the tubes, but on 4.6 i just do it all from the bottom and dont remove anything.
-Rob
Yes , that's what happened to me too lol , it was much easier this time around though . I left the pump on and just moved the rack till I got a good view after undoing the steering column .
Not too bad though , I guess after the first time you learn .
Thanks
Ohh I got away without replacing the o rings , the two bigest Ford dealers didnt have them in stock .
This sucks!!!!!!! I wanna be taking my car in for paint in about two weeks too! been working diligently on this too. Any idea how much time you had into the repair?
Related Threads
TCCoA Forums
1.5M posts
26.8K members
Since 2002
