1 - 2 of 2 Posts
Well, I got my amp hooked up. This mornin as I was drivin down the Highway blastin my tunes,I looked at my volt meter. When the bass was hitting the needle was jumping. The weird thing about it is it was going up instead of down. THe needle would go all the way to the L in normal. If anyone has any theories on this I would sure like to hear about them.
I have never seen anything like that before you might want to check you voltage to verify that your regulator is still good. Also check you altrenator fuse asthis will pop if you go full yield on your alternator.
1 - 2 of 2 Posts
