I am getting this Bird back up and running after sitting for several years (the tags on it are 97). I've run into a number of issues, it seems that everytime I fix one thing and think I'm getting close to being done, something else goes wrong... I think I'm going to have a brand new car by the time I get done replacing everything that's not working... Ok, thanks for listening to my venting, now on to the newest issue:
The passenger side window is having trouble going in either direction. It will move a couple of inches up or down, but stop, although the motor continues to run. I pulled the door panel off to watch what happens, and the window will go fully up and down (with my assistance) and stay there. I can see that the window is all the way down and if I push the down button, the motor runs. Same thing if it is all the way up and I push the up button.
On a side note, when I pulled the door panel off on the driver side to compare, there is an extra plug with 2 male connectors connected to the window/mirror/lock harness. Any idea of what this is for?
I'm guessing it's because the driver's door has extra stuff the passenger side doesn't, like the mirror controls.
motor going bad would be my first guess
ill second that, it happened to my cougar , just waht your decribing,. the plastic gears in the head are shot , replace motor , az is truley your cheapest source on this, they are only about 60 and are new not reman and made by valeo
