1 - 20 of 61 Posts
· Registered
Hello, all you owners of wiring diagrams:
Can anyone tell me if there is any wiring present in a '97 Thunderbird for cornering lights? I mean present anywhere in the engine compartment.
Has anyone retrofit cornering lights?
Thanks!
· Administrator
1994 Cougar XR7 DOHC/5-Speed
The multifunction switch has the outputs but the wiring is not there to it. 94-95s have the cutout templates molded into the insides of the bumper covers even though the option was eliminated after 1992, but 96-97 bumpers don’t, I’m pretty sure the factory cornering lights would fit like crap cosmetically on a 96-97 with the oval indentations
· Registered
Discussion Starter · #4 ·
I was more thinking along the lines of a very low profile LED unit attached under the bumper, i.e., not visible unless you look under there.
So...what I'm hearing is that I'd have to add two pins to the multi-function switch connector (diagram, anyone?), then feed those two wires through the firewall. Ugh...that is a handful.
I do love cornering lights. I think they make nighttime driving through dark residential streets much easier.
· Registered
Discussion Starter · #10 ·
Let me know if you need anything else.
Thank you so much!
It really boils down to the "not used" pins in the multifunction switch connector.
I vaguely remember some people in the Panther community retrofitting cornering lights on non-pre-wired Crown Vics that way (especially when adding Grand Marquis corner assemblies). For some reason certain Crown Vics were wired for it, others weren't.
First I need to select a suitable light fixture and mounting point.
Side note: there's a second reason I'd like the cornering light feeds under the hood. Using relays, I'd like to use them to turn off the parking light/sidemarker function during turn signal operation. Meaning instead of the turn signal going bright-dim-bright-dim, I want it to go bright-off-bright-off.
· Registered
Discussion Starter · #11 ·
Just playing with ideas...
This is a cornering light from a...? (Answer at the bottom of this post.)
Advantages of this fixture:
  • easily available for cheap
  • round, therefore easy to drill a hole for
  • has a outer lip and a rear bracket which screws in from behind, therefore easy to install securely
Disadvantages:
  • round shape may not be a good fit (?)
  • not a good fit for most LED bulbs because the bulb goes in sideways
Here is my mockup:
Ohhh, here is the answer to the riddle:
v
v
v
v
v
v
v
v
v
v
v
v
· Registered
Discussion Starter · #19 ·
That is not the connector you are looking for.
My bad, I actually took this a few nights ago and forgot to post it, the not used pins are the cornering lights
Yes. This is the one. Thank you again. And from what I gather from various diagrams online (Grand Marquis, etc.), the wires go directly from this connector to the lights (meaning there are no relays in-between).
The only challenge now is to find a proper light fixture that produces the right beam pattern and can be installed in an esthetically pleasing way.
1 - 20 of 61 Posts
