I just installed the white faced gauges that I received from Scott this afternoon. I changed the bulbs in it to W5W as instructed and it turned out that all the bulbs that I changed DIDNT WORK! I even tried the old bulbs and they didnt work either. The turning signal, airbag, seatbelt, battery, check gauges, etc. lights all worked. The bulbs that I changed dont work, with the new bulbs or the old ones. If anyone has any idea what the hell is going on let me know ASAP. Thanks
Full Metal
did you blow the dash illumination fuse? check that first before tearing it all apart again.
yes listen to the headgasket King! that's the first thing i would check
Gauge master
Very Cool! Glad you found the problem with the lighting.
Many Thanks for the kind words.
