Sensor testing
I would definitely try unplugging the MAF while it's running. If it behaves the same, that's your problem. Also, just brainstorming here, make sure the MAF is installed flowing in the right direction, there's an arrow on it that should point in the flow direction. I don't know if it even could be put in backwards. Just trying to cover all bases.
It is possible that the MAF was going bad and just disturbing it by installing the filter could have finished it off.
As far as TPS dead spots go, the only way I know to test it is with a multimeter. The TPS is essetially a rheostat with a needle that sweeps across a wound field. The field can develop a spot where it looses contact. To test it, get a multimeter on low voltage DC mode and measure the voltage in and out of the TPS to a good ground. On the output wire, the votage should increase and deacrease as you open and close the throttle. If at any time the voltage drops to zero as you slowly move the throttle, you might have a dead spot. I would start with the MAF first though.
