1 - 20 of 27 Posts
I had a hard time finding articles specifically addressing our cars. I know about the, it makes these cars look cool, aspect, the lower center of gravity effect on handling.
But what, if any, are the negatives? I know to watch out for curbs and such.
What is the best size spring for lowering?
Thanks for responding. Back in the 1950s I remember people were heating spring to lower cars.
Go Vogtland or Eibach. By size I guess you mean drop amount. Vogtlands come in 1.6 and 1.0" drop sizes. I don't know much about the Eibachs, IMHO Vogtland is the best.
Cons are a harsher ride - you trade comfort for performance. You'll need an alignment after they're installed and that's about it. You'll want to replace the shocks with something firmer. There really is no point in putting performance springs on a car without performance shocks IMHO.
1994 Cougar XR7 DOHC/5-Speed
I don't really think there's a "best", as long as the specs fit your desires. Me I way prefer my cut Tokicos to Eibachs(I utterly hate the way those ride). Vogtland has the prettiest color :tongue:
Negatives other than firmness(which I don't consider negative) and scraping, which is inevitable with any drop over an inch, is really that you're close to the ground and these cars in relation to most 2016 era CUV/SUVs infesting the roads out there, so if you have a hard time seeing around other cars in traffic now, it'll only get worse, but you'll look cool so who cares :tongue:.
On the cons list...
Depending on how low you go, scraping over speed bumps/surface irregularities can happen more often. You lose wheel clearance to the top of the fenderwell, but in most cases that's not a big deal. Hasn't been an issue on my 18x9 wheels yet.
I am running Eibachs and I like them. It is more firm than stock, but still a very comfortable ride even with my 255/40/18 tires and KYB GR-2 shocks. I plan to upgrade to Tokiko Blues eventually.
From what I hear, the Vogtland springs are the superior choice for cornering ability, but have a harsher ride than the Eibachs. From my understanding, the eibachs are out of production for our cars.
One thing to take in to account is condition of the roads. When I lived in GA I had no problems with my 1.5" Eibachs, now in AR the roads are so poorly maintained I scrape going down State Highways (ruts from lack of resurfacing or not properly done job to begin with).
Northern MN isn't much different. I have to drive all over the road to avoid frost heaves, pot holes, etc.
If I remember my research correctly (its been a while) the Eibachs (if you can find them) are progressive springs meaning the more they are compressed the firmer they get. The Vogtlands are a... forgot the word... anyway they have a constant spring rate. What that means is that the Eibachs are softer on the interstate and firmer when pressed into corners. The Vogtlands are the same in both conditions. For this reason I liked the Eibachs. But, as they are out of production now unless you can find some NOS or used ones your only choice is the vogtlands. In my opinion the pros far outweigh the cons as far as lowering. (so long as its reasonable anyway)
Would a simplified statement that accurately describes the information said above, be if you prefer a smooth ride with less NVH with a floating type feel then one would go with a progressive spring rate such as eibach, the flip side being if you want to feel your car firmly planted and be in tune with your cars entire handling then one would go with the linear spring rate such that of the Vogtlands. Orr am I way off here?
They're Coke and Pepsi. There isn't any difference except for personal taste.
The most important difference - as Traveler said - is availability - the Eibachs are out of production.
For the sake of argument, if you don't want to feel a speed bump at 20 MPH then stick with stock.
Linear is the word you're looking for but a few clarificationss: ALL springs get firmer the more you compress them. Meaning if you compress a linear spring rated at 326 pounds per inch, it will take 652 pounds to compress it 2" and so on. Progressives work like two linear springs on top of each other, one with a low rate and one with a high rate, one will compress quick for minor bumps and whatnot and when it compresses enough to reach the second rate that firm section of spring is now doing the work.
Vogtlands are in fact progressive, and I believe most lowering springs made for these cars were, minus Tokico and I think ST(H&R maybe? Some acronym lol), but Vogtlands just use a much higher initial rate than Eibachs do. Think of it this way:
Vogtland = Shorter Sport(JJJJ) springs
Eibach = shorter LX springs
Eibachs initial rate is about as soft as non-sport springs LX springs(which are linear) at 270lb/in IIRC, whereas Vogtlands initial rate is in the 340 lb/in range like sports. Both get into the 400s when you push them, but that super low initial rate is why I dislike Eibachs personally, I don't like the way non-SCs/sports ride in any situation, Eibachs try to preserve that mush and the transition to firm when you push them is like an on/off switch.
I noticed that plopping my hefty ass on the rear quarterpanel only moves the rear suspension, about 1".
A well damped motion, but damn. I'm not a small guy.
Further analysis made me realize that as light as the rear of the car is, I can't really use sport springs.
I'm going to go back in with the OG springs, and see.
Oregon's full of cool twisty roads, some of which are bumpy.
Looking at it from that perpective---
-- lowering a car generally puts it at risk of hitting the suspension bump stops in a corner when traversing a bump or a dip in the road. If the car car does hit the stops, and you are driving fast, the end of the car that is bottomed will momentarily loose traction. Sometime you can trim the stops back a bit if they are rubber or urethane to help maintain bump (jounce) travel in the suspension.
Dont know the specifics of a T-bird, but it is something to look out for.
Since most of the twisty roads here in Washington are bumpy, I find that when I lower a car to make it look good, I generally end up regretting it, and revert
back to the stock ride height.
This conversation makes me think I would be better off lowering the front but not the rear. By the time I reinstall my sound system and add a battery into the trunk my rear tires will perhaps have an inch of 2 of clearance again. I suppose the right lowering springs could leave me just as much clearance but it still looks like I only need lower springs in the front. Then again if I had my way I'd have smaller wheels in the front as well.
You might want to consider your tire height too. I have tires that are shorter than stock and I got a deal on the 0.9" Voigtlands. My car rides pretty close to what 2" lowering springs would give on stock tire size. I have been hitting the tips of my exhaust when I try to enter steep residential driveways but that's about it. Not too bad.
I didn't drive my car very much or very hard during the replacement of the front end, all new springs, new Tokiko shocks, new brakes, and new steering rack, so, I can't say what the springs would do by themselves. There is definitely less body roll than my stock springs with 170k on them.
What Grog said above kinda hits home with my setup. There's still some softness in the ride that is just enough for highway cruising but if the bump is any size at all I'll feel it more than I used to.
Thank you for the clarification. Based on what you have said, I think a set of Vogtlands may be in the future of my wife's Sport Tbird. :)
Discussion Starter #20
In case of a flat tire will I wish I hadn't lowered the car because the factory scissor jack won't fit? I suppose I can keep a short piece of lumber in the trunk to use as a ramp to raise the car. Has anyone faced this issue?
1 - 20 of 27 Posts
