I have had a shudder for a while now and have replaced plug wires twice, replace TC with the Mark 8 and now have replaced the tranny with a mark 8. Still have a shudder and under WOT it feels like it is slipping, but could of been detonation after what happened today. Today I decided to pull out my 2nd Gen. Customchip that i received a couple years back and now it still shudders but also as soon as you get on the throttle a bit it detonates like crazy. I turned the car on and pulled each plug wire one at a time and each one did the same thing, so I dont think it is the plugs or wires. Anyone have any Idea why it got worse when I pulled the chip? Could it be the coil packs?
Thanks
STeve
Try pulling your octane plug out if it helps then it is timing related
grey plug (solid) by the MAF
Curt
pulled plug and still the same result, I guess it is more of a miss or hesitation than a detonation. Almost like its not getting enough fuel. With that chip in there will it send more fuel than without it. I just dont get why it is so much worse without the chip.
Maybe clutch packs in the trans going bad. Does the shutter get faster with speed? Could be U-Joints. If a coil pack goes bad it just won't fire. Your ignition module might be firing the coils iradically. Try a lower grade fuel. If you have been using a low grade fuel try a high grade fuel like 93. If your gaps are set to stock .054 and it feels like a shutter or miss then try a gap of about .044. You could also have a bad injector (my stock 19# had a bad one) or the pressur regulator might be flooding under load or running your car lean under load.
I'm no expert, but a little advice helps
Clay
Put in new AWSF-22c's in today and no more detonation or shudder, some times you learn the hard way. doh
