I have a '94 Mark VIII and am having trouble with the check engine light, and idling. The car sometimes does a bouncing on the RPM's when idling. I pulled the codes and got a 538 which my books says is "unable to control RPM's", and a 214 which was "cylinder ID failure". I called Autozone with these and asked if it might be the throttle position sensor. Their manager said he thought it was the crankshaft postition sensor so for $15 I tried that. No luck. On a side note, I have replaced the O2 sensors, and it has newer FMS 9mm wires and new Autolites. Any suggestions on what I should try next? Thanks in advance for any help!!!!
Matt
I'm not sure if this will help or not but try cleaning your MAF sensor. There is an article in the articles section of this website that tells how. :) That might cure the idle fluctuation. I have no idea where to tell you to start looking for the cause of the cylinder ID failure problem. Maybe the cam sensor(s)?
