if i get just the ASP crank pulley, should i worry about any charging or cooling changes? i have read that some people experienced changes in charging and/or cooling or have had a dead battery result after installing pullies. should i have anything to worry about? thanks.
93 tbird non sc
Refrigerator Raider Hater
You can find the difference by measuring the stock and aftermarket pully. A crank pully 10% smaller will effectively underdrive all accessories 10%.
If I get the crank pulley from rpm-mustangs.com should i have any problems with charging? i have a 3.8 n/a and i have a standard 45 watt stereo system. Any problems ??
what about with the cooling??????
b/c ive heard this also, that the car tends to overheat.
marvin M.
No problems here- charging or cooling- Only problem i could see is if you sat idling a lot with a big (BIG) stereo system.
