hey all,
After reading a post from Thomas, I pulled codes from my 91 (eec-iv) this morning when I got to work and got a list that was a mile long !!! I thought the codes were 3 digit so I had to decode my decoded codes, make sense? I read, in a post here, that the codes are erased after being displayed, so I figured I would do it again when I got home. My CEL came turned on & off all the way home. I checked the codes again and it was still LONG. I lost count but captured a few codes ( like 8 or 9) Does anyone have a list of codes for our cars?
Look in the tec articles under misc. The complete list of codes is there.
Thanks, just wish I could print it out.
I pulled codes again this morning after I got to work and here is what I got....
1,1,1,1,1,1,1,1, (pauses between all)
76
17
73
26
32
73
37
17
71
77
32
63
27
33
7
I don't understand all the ones in the begining or why it stopped on a 7. All these codes are "key on engine off". Could some of those codes be 3 digit? Would it be easier for me to go to Autozone and have them check it? The numeric codes will come up on their scanner right? I'm so confused.
okay if I group them in 3 digits from the end of the group I get....
337
327
326
177
177
333
327
326
177
176
111
111
11
:confused: :confused: :confused: :confused: :confused:
okay let me try again,top to bottom
11
111
111
176
177
326
327
337
then it repeats. I do believe I miscounted the 176 before the 177, as the eec should not throw 2 identicatal codes in a row. Am I on the right track......anybody...bueller....bueller
Trumpeter Extraordinaire
I'd say get the codes scanned, or get a scanner and do it yourself, mainly for the sake of accuracy.
Here's a PDF file to assist in deciphering what you're reading. Some point to EGR problems, O² sensor issues, throttle position sensor - depending on how you read the codes. For example, one of the 3-digit sequences you have is not on the list I linked to...
Good luck to you.
