Going to change all the oils and fluids this weekend...
There's just one thing I need to now before I
order everything...
The gasket in the rear of the pumpkin...
Is it okay to order any gasket for a 8.8" Ford pumpkin
or are ours different since it's an IRS pumpkin... ??
Thanks!
//Thyg0d
not sure.. If you were in a bind there is always a tube of Gasket maker :)
There was no gasket installed from the factory, Ford doesn't even sell them. Just use some good quality RTV sealer.
cheers,
Ed Nicholson
SCCoO
.. I like his idea better....
:D
Really..? No gasket???
Strange...
Well I've got a large tube of gasketmaker
from Loctite.. When I bought all the stuff I actually got a
Felpro gasket for an 8.8 inch Ford rear...
Not sure if it fits though..
Thanks a lot for your help!
//Thyg0d
When I said "Ford", I was referring to their regular replacement parts division. Ford Racing sells one that is supplied by an aftermarket vendor. :)
cheers,
Ed N.
Thanks for your help!
No problems in using the new gasket...
HOWEVER!
It took me 5 hours to get the U shaped holder off...
I've been working on cars up to 35 years old but I've never
found anything that stuck!
:D :D :D
I mean, ususally they do loosen a bit when you
heat it with a blow torch...
Ended up cutting the bolt... :mad:
Well... There's a new one on there so everybody's happy...
//Thyg0d
Cougar Pilot
My mount was also very much seized on there. I sacrificed a 12"+ new Blackhawk ratchet, a socket, and then finally the bolt itself broke. Garage still smells like gear oil. mmmmm
