I have an absurd amount of MN12 stuff in my shop. It's time to thin the hoard. If you're local and want to take a bunch of stuff - I will hook you up.
This is nowhere near everything. If you need something and don't see it, please ask. Prices will be PLUS actual shipping.
Various SC side skirt pieces. White/Silver/Red. There is enough here to complete a car plus an extra set of door pieces. There are 2 sets (plus a few) of the clips to hold the door pieces on. There is a very rusty set of the steel mounting rails that would be a decent pattern to make another set.
Everything in the picture: $150
Complete set (6 pieces, door clips, mounting rails) : $125
Door pieces with clips: $50
-PENDING- Eibach 3524 1.5" lowering springs - used : $100
1989-1993 center console lid: $10 each
1989-1993 center console cassette tray and rubber mat: $5
M5R2 stock shifter parts: $5
-SOLD- 'Cold Air Intake' airbox for a cone filter (This mounts in place of the OEM airbox to create a wall between the engine bay and air filter. I never used it) : $40
-SOLD- Fabric (felt?) dash mat for 1994-1997 - grey : $5
Random gauges and mounting brackets: $10
Ignition coil for 1989-1995 3.8L N/A (one stock, one Borg Warner Select) : $10 for both
Distributor cover for 3.8L or 5.0L - rubber : $5
-SOLD- FN10 trunk net: $5
-SOLD- Rear-view mirror with map lights and wiring harness (not auto-dimming) : $5
FN10 shock tower covers: $15
1989-1995 SC Auto Ride Control shock tower covers: $15
-SOLD- MN12 stock battery hold-down bolt: $2
-SOLD- 1989-1995 OEM fog lights/brackets (no bulbs/wiring) : $50
OEM Premium Sound amplifier F4BF-18T806-AA : $20
IRS subframe bushings/cups - used (4 upper cups, 2 lower cups, 2 upper bushings, 2 lower bushings) : $30
1989-1993 interior door handles - chrome : $10
FN10 4.6L DOHC ignition coil covers: $10
4R70W MLPS sensors: $20 for all 3
1989-1995 SC Auto Ride Control shock actuators: $20 for all 5
Yellow fuel injectors - unknown condition (was told these are from a V8 SHO) : $10
Red fuel injectors - unknown condition (Supercoupe 30#): $30
Auto Meter 1385 Quartz clock - New-in-box (LINK) : $10
-SOLD- Chrome fanblade wheel hubcaps - set of 4 : $5
-SOLD- 1989-1993 SC hubcaps
1997 cupholder console top - black : $15
-SOLD- Dome light / sunroof switch - red : $5
Ignition control module (came from 1994 3.8L N/A car) : $10
SCUI hub-centric rings (needed to run re-drilled Cobra rear rotors on MN12 hubs) : $5
Various random suspension bolts: - Tell me what you need
SC brake pedal assembly for manual transmission swap: $75
SC clutch pedal assembly (both have un-damaged pin for master cylinder - see pics): $225 each
