1 - 1 of 1 Posts
First I want to know what are all the outlet connectors on the Throttle Body and the Inlet pipe. There are 3 outlet hose connectors on the inlet pipe to the Supercharger that is on top of the inlet pipe and 2 outlet hose connectors on the throttle body that is on the bottom of the throttle body. I need to know where do they all connect to.
Now for the PCV valves, one connects to one to the outlet hose connectors on the inlet SC pipe that is for the left Valve cover now the right valve cover has a hose like pipe that can reach to the left cover but I know you can't connect both of the right and left connectors together, one is for oil and the other one is for air or I could be wrong. If I am wrong then where does the right PVC hose connect to then?
Please help Thank You.
1 - 1 of 1 Posts
