Is it possible to have active Pxxxx codes and NOT have the CEL light come on?
The CEL bulb is functional. It comes on when I turn the key without starting the car and goes off once I start cranking the starter.
Ten minutes of search yielded no answer. Thanks...
I'm no expert on OBDII, but I've pulled codes out of my vehicle when the CEL was not on. If a diagnostic was performed, and threw a code, then performed again, and passed, the CEL may go away - the Pxxxx code is still logged in the PCM, and can be viewed.
you can have a P1000 and no CEL
