1 - 11 of 11 Posts
Sheepish
Would the speedo out of a 94-95 SC be a plug-and-play installation on my 95 LX or would I have to have something recalibrated?
Yep, just did it to mine wednesday. All the calibration is in the speedometer itself.
<img src="http://www.mn12tbird.com/dash/dash01.jpg">
Sheepish
Discussion Starter · #4 ·
Sweet...thanks for the info guys!
MN12 Fanatic
How did you swap to the voltage guage in it ShadowDragon? Did you just take it out of the original one and wire it into the new one? It did come with the boost guage right? BTW, it looks good!;)
Sheepish
Discussion Starter · #6 ·
Aren't the temp guage, the speedo, the voltage/fuel, the teach, and the oil guages all separate pods that just literally plug in?
Actually I just took the speedo out of the SC cluster and slapped it into mine.
The boost/fuel and battery/fuel are one gauge, but you could get away with getting that module out, then unscrew the back of the fuel gauge and take it out and match it up to your faceplate.
Front of the module
Back of the module
closeup of gas guage
MN12 Fanatic
Okay! I get it now! Sounds simple...
Thanks!
ZackG said:
what about sc guages into a 97?
Totally different cluster, sorry. Look at Greenbirds post on the SHO cluster for your 97 though. You might be able to get away with swapping out a SHO speedometer, but I've heard the coloring is slightly different.
1 - 11 of 11 Posts
