so i just wanna make sure. iv been told a 93-98 mark 8 pan will work on a explorer motor. and u DONT need the pick up tube right? i wanna do headers while the motor is out so it will all fit right?
k so any of those years right? and will fit with the headers? iv been two u dont need the pick up tube and then iv been told u do.
Fry Rice Specialist
the pick up tube is almost the same between the 2.
same diameter and pick up depth.
Refrigerator Raider Hater
It's a case of whether you want it to say MN12 or FN10 stamped on it. You only need a mark 8 pickup if you go with the HO oil pump.
soooo is 93 - 98 is all the same..?
93-98 pans are the same, only thing changed was the pickup for the high output oil pump.
Mark8 pickups also have an oil scraper brazed onto them that the Tbird pickup doesn't have.
