I know this needs to be fixed and it will be as soon as I can get the car on a lift. When I did my transmission (3 weeks ago roughly) I pulled the motor and transmission together. I reinstalled everything as one unit and bolted the exhaust up. Now I know the flanges are leaking. Obviously the down pipes are not straight with the manifolds. (They looked ok when I bolted it in.) So obviously I have a clapping type noise from the exhaust. Ever since I've had bank 1 and 2 upstream lean codes.
I'm curious if the major exhaust leak would be the culprit. I know the onlyway to really find out is to just fix it but I dont know when I'll be able to get the car on a lift and I think using a jack or ramps flexed the body enough to make it straight when jacked up but when the car got lowered it moved the exhaust.
Am I right on this?
So we are clear,
LMAF is brand new, No vacuum leaks, Good sensors.
Ok thanks. I wasnt 100% sure but I figured I'd ask. I suspected. I'll get it fixed ASAP.
