Can the front hubs be swapped from side to side, or do they need to stay on the side they were originally installed on?
I grabbed a set off of a 95 T-Bird with low miles, but never marked them as to which side they came off of.
AED Specialist
Front Hubs are the same left to right. The new hubs all have the exciter ring on them for the ABS, regardless if you have ABS or not.
Talking new of course. Engineers would not like to see you remove a USED hub/wheel bearing and swap it to another spindle on the opposite side. New...doesn't make any difference and the p.n.'s are the same.
A-Train
