1 - 19 of 19 Posts
They're a lot cheaper on eBay though...
$10-$15 a pop on ebay, sometimes you'll even find a pair for that much.
The back of the remote has the following on it:
TRANSMITTER 1
FCC ID: GQ4343CT4T
DOC: 1470 K763
TRW Inc 3165189
I got one on ebay and never could get it to program to my car I think the dealer told me $60 to set it all up and everything. I wondered if something was wrong with my car because the remote wouldn't program but my original one still worked, intermittenly...
Alan
Matt, have you noticed if some remotes have better range than others? I probably need to replace the batteries and clean the contacts on mine, but it seems like its effective range is only about 20-40 feet with no obstacles, and I often have to press the button(s) multiple times to get a response - where most newer remotes seem to have no issues over distances twice that far with obstacles.
Discussion Starter #16
hey guys, i got another question... How do i make the car flash it's lights when arming the system? it gives me a beep when i lock it, but the lights dont flash
Can someone will like to elaborate on how to program this remote to your car. I will definitely will purchase one if I learned how to do it.
Many, many threads on how to do this........
Google.com search for:
site:tccoa.com Keyless Entry Programming
The first few results:
http://forums.tccoa.com/showthread.php?t=134564
http://forums.tccoa.com/showthread.php?t=20135
http://forums.tccoa.com/showthread.php?t=138788
http://forums.tccoa.com/showthread.php?t=23939
http://forums.tccoa.com/showthread.php?t=130053
I investigated this briefly a while back. No reliable way to do it without coming up with some sort of IC.
Can someonewi ll like to elaborate on how to program this remote to your car. I will definitely will purchase one if I learned how to do it.
Step 1 - Install a relay harness for your lights, so that you have an easy method of blinking the lights.
Step 2 - Examine carefully page 111-4 in the EVTM for hints.
Step 3 - Wire up the proper logic.
Profit!
1 - 19 of 19 Posts
