1.. my cruise control sometimes surges when its on..?
2.. which transmision line do u tap into to run into a trans cooler, top or bottom? :confused:
Discussion Starter #2
never mind the 2nd ? forgot about the technical articles section..
think it might be a relay?
yea thats what it does.
no jus sometimes it seem like its runnin out of gas . thats how it feels to me ..
Vacum leak............
I'm wondering if you've got a small leak in the vacum line to the cruise control actuator or a leak of the actuator's piston. Trace the lines from the dump valve at the brake pedal to the actuator in the left front fender well. Give a big inhale to the supply line, does it hold it's vacum? How does the dump valve by the brake pedal look, is there any crud in it?
Just my 2 cents
Chris....................
thanks have to try that one..
