1 - 13 of 13 Posts
whats is an IAC??? what does it do and where is it located at on a 91 thunderbird 3.8Lnon sc??? and does anyone have an idea about how much it will cost to replace it???
Thanks
Jay
Discussion Starter · #3 ·
HAHA thanks man for tellin me what it is....and not confusing me...by any chance do u know where it is located at on my car...its a 91 t-bird 3.8L non sc
thanks again
Jay
Discussion Starter · #4 ·
ok 1 more question....well hopefully last one anyways :)....ok is it called a IAC sensor?? just so i know what to ask for when i call auto zone or whoever i call
thanks again
Jay
I've also seen it called an idle speed control sensor. On the 3.8 it's located on top of the throttle body, almost looks like a small tranny! Not sure exactly what it does, but if your idle is lower than it should be or jumping up and down this is usually the culprit.
Discussion Starter · #6 ·
ok is it black and bout 3-4 inches long and has a spring on the inside of it....and a sticker that says do not adjust spring on it and 2 screws hold i down???
IM DUMB WHEN IT COMES TO THIS STUFF SO PLEASE BARE WITH ME YOU GUYS
Thanks alot
Jay
Generally...
Ford calls it Idle Air control Sensor...But every after market place will have
some differnt name for it, but it will be similar enough to let them know what your talking about....They will know what you want
BeirutsFinest
Pedal Faster
It makes fine adjustments to the idle (fast idle when cold, A/C compressor on, slower idle when warm, etc.)
Hope that helps a little.
Discussion Starter · #9 ·
thanks man...do you know what a TPS sensor is and where it is located at on a 91 t-bird 3.8L non sc???
thanks again
Jay
Discussion Starter · #11 ·
ok well thanks man ur been a big help
gues i need to buy a book on my car
thanks again everyone that helped
Jay
Pedal Faster
They're both on the throttle body... which is which, I couldn't tell you.
Discussion Starter · #13 ·
ok well i know the idel air control sensor or the idel speed control sensor whatever you prefer to call it is located ontop of the throttle body..so my guess is that the TPS sensor is the little thing on the backside of the throttle body???
Jay
1 - 13 of 13 Posts
