I just noticed my tranny is way past full on fluid.what if any damage will this cause? What's the best way to drain some without dropping the pan? Thanks
Assuming you are checking Fluid level correctly with Engine running easiest way to remove Fluid is with a Marine Siphon Pump fm Walmart via the Dipstick.
Be sure that you are looking at whether it is on the hot or cold line also..but as said before, check it running and on level ground.
