did a search on alldata for MPLS on 97 cougar no such listing.
is the MLPS called by another name such as
"Transmission Position Switch/Sensor"
"Shift Interlock Switch" or
"Transmission Mode Switch"
these are the three trans related swithcesother than the speed sensor and temp sensor i found in the 97 cougar diagram
the tps is the only one located need the trans the other er are on the steering column and under the dash.
Is the "TPS" the same as the MLPS?
MN12 Fanatic
It's MLPS (Manual Lever Position Sensor).
AKA Neutral Safety Switch.
And the TPS (Throttle Position Sensor) is located on the throttle body....
3rd Gear Chirper
Gotta love NoData.
It's one of those two.
