1 - 2 of 2 Posts
Hey I wanted to know if anyone knows if there is another power rack and pinion from lets say a Mustang that will bolt up to my 90 SC 35th? I think my power steering rack may be going bad and figured since I autocross I might as well see if I can adapt a different power steering rack with a quick ratio while I was at it. So I would really apreciate it if some body that has done the swap before or knows of the correct part to tell me if there is another power steering rack that will bolt right up.
Shane
I think some people have swapped to a manual flaming river setup for the reduce weight, but state that you don't want to go manual unless its a car for the strip or you have drastically reduced weight on your car. A lot of the threads on the tubular K member talk about this.
1 - 2 of 2 Posts
