Yesterday, I replaced my inner/outer tie rods and lower control arms with motorcraft and moog parts. Went to get it aligned at work and noticed the new passenger side inner tie rod had some play. Double checked to make sure it was nice a tight, and found that the play is actually in the rack which attaches to the inner tie rod. Is my rack bad or is there a worn bushing or something causing this?
pita to rebuild the rack anyhow, just replace it. get a whole new unit with new inner tie rods.
Well that sucks. Ill just roll with it until the motor is out and put in a new rack then.
