1 - 18 of 18 Posts
My radiator went out on me last week, the upper hose connection broke and the hose popped off. The plastic literally disintegrated. There's not enough plastic left to hold the hose on. So I got parts on order. I'll be replacing the hoses while in there. Is there any reason to not replace the water pump?
That sucks. No reason to not replace the pump if it's original. You'll need a pry bar.
But I would get a Motorcraft if possible instead of a "5 year" pump that Advance sells. Everything they sell lasts 5 years tops. I replaced the pump twice on Brenda's Cougar because I went to Advance.
Al
  • Like
Reactions: GreenT
SuperNewbie
1995 Thunderbird LX 4.6 red
I'd replace the pump. It's a simple job.
It's debatable if there's any real (measurable) difference, but the PW470 from the Cobra has been reputed to free up a tiny bit of power and improve coolant flow due to the closed-vane design of the impeller.
SuperNewbie
Most of the pumps I've picked up from autozone in the last few years actually have the closed vane impeller.
Sorry for being a decade or two out of date, as usual. :ROFLMAO:
I'd say the cobra bump is pricier than a GM pump.
Get an electric Meziere pump. Model # WP346S
Here are a few sources.
Great pump. Should last you years.
Thats what my junk has, Meziere, has lasted12 years, four as a daily driver, three more as a weekend warrior,
the rest as a trailer queen.
I run an Edelbrock pump.
97 Tbird Sport
Be glad the tank didn't puke in your tranny. That costs more than a large aux cooler to bypass the radiator for the Trans cooling.
Discussion Starter · #14 ·
Ordered the water pump listed for our cars, it is a closed vane. The one I pulled off was open vane, so I assume it was the original.
Got the new radiator, water pump, upper & lower hoses installed. I also pulled the overflow and cleaned the inside the best I could.
Drove her to work to day and she seems to be running cooler. The ride home will be the test, it's currently 97* out now.
Adding a large trans cooler is a must for hot weather; the 3-4 and 4-3 in traffic seems to be what overheats them. The factory shift pattern drops out of 4th with minimal throttle. I saw the temp go from 200f to 500f in a minute, driving in 70mph traffic.
1994 XR7 , 46 most every option. 66.000 miles. rustfree, from washington state.
thats what i put in when i got my car. that , pulleys, and serp belt.
I finally made it home to share a picture. I had previously posted pix of my cooler but those pix were linked to Photobucket and we all know what happened to those pix when PB broke the internet.
I bought Three 48k btu coolers from Alan hears ago; I did mine similarly, but bought some 1/4" open area, 20awg stainless mesh from msc to go in front of it.Road debris will waste them here otherwise.
1 - 18 of 18 Posts
