Alright i'll add on to what the title says. it seems right after i cleaned my maf then reset my cars computer via the fuse it has been doing this.
But it could also be from my intake swap i did with the alum cooling tube it only had one sensor where my old one had 2. so i only connected the one to the left(passengerside) and left the 2nd conncter un connected.
I know its better to always have it on but my fan is amazingly loud for some reason, it drones out my exhaust!(magnaflow di/do).
anybody know whats going on?
could it possibly be i have a bad t-stat too?
I think your problem would be with the second coolant sensor plug left unpluged. I believe that one is for the EEC and the other is for the temp gauge in the dash. If your gauge works the EEC is not getting the signal that it needs. This should turn on the check engine light as well though.
Doug
It doesnt matter, I had the same problem. I changed the sensor and it got fixed. Check it
Replace the stock sensor. No second one here
Israel
