1 - 1 of 1 Posts
I wanted to say thanks to the forum. My radiator fan burned up this morning in traffic, and armed with the info I was able to find here, I replaced it tonight.
I got the Dorman OEM replacement from Advance Auto, and it's an exact fit. With the correct plug. $114 out the door.
I had to remove the battery cable and overflow hose to get the shroud out. It'd have been easier if I could've gotten the upper main hose off, but some dimwit put on the clamp facing down and I couldn't get pliers on it until after the shroud was out. Putting the new assembly in was a simple drop-in after I removed the top hose.
If I hadn't had to fight with the hose clamp, it would've taken 20 minutes, tops.
1 - 1 of 1 Posts
