Wow... sounds like a snap.Casper said:radiator? super easy.
drain coolant, remove the 2 top bracket (10mm), fan wiring pigtail, unbolt fan (4 10mm), remove fan, disconnect top radiotor hose at the raditor and bend it away, lift up the raditor, remove lower hose, then the whole radiator is out.
