1 - 20 of 31 Posts
okay, so i have neglected to fix a power steering issue for almost a year and a few days ago i went to turn right and heard a snap then my wheel was able to freee spin... after further investigation the rag joint has come off of my rack... my knowledge of the steering is minimal so i figured id better ask for opnions on if its shot or not... is there supposed to be a bolt through it? or how is it held onto the rack? this is a DD so fast responces would be super helpful!!
Pics would help. Can you tell if its broken where it mounts or the joint itself?
i didnt take pics... should have though!! its stuck at work... i dont think its broken, it's jsut like it can loose or apart from the racks splines.... very odd just a big clunk and i looked at it and it was just chillin about an inch from the splines does a bolt hold it into the rack'ssplines?
It should be collapsible. So grab another bolt for the rag joint and try to pull it back out. Be sure to line up your steering wheel correctly first
yes 2 bolts on rag. one holds it to the steeringwheel side one holds it to rack side.
What was blacked out?
That was a Government-redacted photograph. He had a classified ID number, and the name of the Grassy Knoll shooter printed on the crossmember, so of course they had to black it out.
So can anyne tell me an aprox. Size and if I need a nut or just a bolt? Gonna try to tet this goin again tonight
Make sure not to let the wheel spin. If you do there is a good chance you'll 'over-turn' the wheel and break the clock spring.
While we're talking clock spring, is there a procedure on how to ensure the steering wheel is "centered" when installing a new rack?
Assume the wheel got turned by mistake while the rack was out... :-(
There may be a method, but I am not aware of one.
If that happened to me, I would remove the clock spring and reassemble making sure it is centered.
Usually I tie the wheel to the seat frame with a strap or rope while it is 'free'.
The clock spring assembly has directions printed in the plastic:
"Rotate ccw until tight, then about 2 3/4 turns cw till the marks on the case line up."
Theoretically, your steering wheel should be level there. :zdunno:
I just happen to have one laying here beside the computer, lol. ( Thanks, Splattered!)
Discussion Starter #15
upon further investigation i snapped it!! :D i feel special... thankfully my parts car's was not broken, i figure by the looks of it, it'll last about 6 months, so that will give me time to save up for the stainless steel one!! so i have a long week ahead of me!!!
DLF makes a bolt on piece but it can be duplicated using a flaming river joint and a small length of modified shaft. DLF's part is a good price though
huh huh huh (beavis and butthead laugh)....he said 'joint'....
Yup, anyone can do it, if you want to buy at least 18" of stainless DD shaft.
1 - 20 of 31 Posts
