My wife's 2000 Taurus has recently developed a strange problem. It doesn't happen often, but twice now in three days, when she turns the steering wheel sharply the car dies. Both times, the car has been at a near idle, but under no extreme load. She had a check engine light on for the DPFE sensor, but when it died the first time, the light went out, and hasn't returned, yet. I'm having a hard time figuring out where to start. My first thoughts are a vacuum leak because of a braking oddity and the DPFE sensor. Maybe some strange electrical issue, or fuel. Any recomendations? Thank you for the help!
Scott
Bloomington, IN
Does it sputter any before it dies? If so, then I would guess maybe some water in the tank. . . . .Other than that I would have to guess an electrical short.
Just my .02 but it might be the PS pump giving up the ghost. I had a similar problem on my 4cyl mustang. When I turned right, the engine would sputter, and eventually die if I held the wheel there. Once the pump was replaced, everything was good to go.
That could emplain a few other things then too. Her car has always been hard to turn, meaning, you had to swing it like a school bus to get into parking places, and around corners, but other Taurus's that I've been in haven't been that way. I'll take a look at it and see. Thanks for the input!
