Hmmm....I assume these are infinite baffle subs? What did you do to isolate the front from the back wave? If they are indeed IB subs, you should NOT port them. Ports require tuning. If you don't know the PRECISE amount of space behind the subs, you can't possibly get the tuning accurate.anomnity said:after this i aligned the boards up and then screwed them into the tin...then after this i put the speakers in to holes and waa-laa...
also im putting port holes in between the 2 speakers...thats why everything is out at the momment...makin' new theories for sound quality.
Now if you've actually constructed an enclosure below the deck for the subs, that's a different story.
