It has frozen over completely down here for the first time in years, and i need to use my rear defrost. when I got the car in '04 the rear defrost worked, but the tint wasn't so good. I peeled it off, and I guess I tore off the brown stuff or something that was all over the window, and one of the connector pieces broke away from the window. I now have a new tint on there and the defrost does not work. Obviousy because the little Wire connector piece is not attatched, but if I just like solder that back or something, would it start to work or what?
-thanks
master486 said:
I've seen repair kits specifically for heated rear windows in auto parts stores. You could try that, but who know the damage that has been done.
master is right, I had to fix mine after the tint shop jacked mine up.
roger said:
and I guess I tore off the brown stuff or something that was all over the window, and one of the connector pieces broke away from the window. -
If you did tear off the brown stuff from the rear windshield, then hooking the connector back up won't help.
