make the entire thing work?
Well, not sure of width, might be okay
need to have a upper and lower arm mounts
a watts linkage mount
probably need upper shock mounts
probably need upper coil spring pockets
then at this point what about the gas tank, that relies on the driveshaft that doesn't articulate up or down? not sure there is room
probably have exhaust issues
Find an 88 TBird for a solid rear axle. Not just the axle, the entire car :)
SuperNewbie
1995 Thunderbird LX 4.6 red
Make it work in an MN12??
A 83-88 Thunderbird...
And then it's a moot point because it'll already have one. :D
Are you asking about the entire axle assembly, or just the differential?
if just the "diff", it doesn't say if it is trac-loc equipped or not, but:
open or trac-loc, the carrier is 31 spline
3.27 gears, aren't those what you already have?
If the entire axle, you know you have an IRS rear end, right? To install the axle would be a ton of work.
1994 Cougar XR7 DOHC/5-Speed
if you want to use the whole assembly its alot of work that, well.... no one has tried (with the exception of backhalfed tubbed drag cars).
if you want the trac lok and gears alone its way too much money, and still will require work to use with the IRS.
