How hard is to change the rear sway bar end links. can i just change the bushings that go from the link to the sway bar? what tools of what sized will i need to do the job? thanks for the help guys. Jess
Well since you live in oklahoma theres probably not much rust on your bird but theres a nut on the buttom that has to be taken off. Yes you can replace those bushings but i'm not sure if you can just buy them with out buying a whole new endlink. Also you have to remove the upper part of the link thats on the sway bar.
On mine, it was the bushings in the upper end that were rotten and causing a bit of a rattle. I bought the poly kit from MN12 Performance to replace mine, and while the bar bushings are a tight fit, and they they to be greased periodically (I put grooves and grease fittings in mine, and hit them with a shot of grease at every oil change), it's a nice, fairly inexpensive upgrade.
what kind of tools will in need? i dont have alot of tools and i hate getting half way into a job and having to go buy something so what size of wrenchs and sockets adn such will i need? Thanks agian guys. and ohh yeah there is a fair amount of rust the car is an ex- texas highway patrol car. thats waht attracted me to is the motor and tranny are great but the suspension is shot. but agian thanks for the help guys. Jess
Basic metric hand tools (sockets/wrenches, I think 13 and 15 mm were all I needed), possibly a c-clamp and a third hand to hold the sway bar bushing brackets against the subframe (if you replace them).
Don't crush the lower end link bushings too much. The upper bushings use a metal sleeve to prevent it.
It's a little easier with the rear wheels off. May as well see what else needs work, too.
And a lot of PB Blaster to free the rusted parts.
thanks guys. its gonna cost me like 60 bucks for parts plus what ever for tools but you guys still rock. oyur the only forums that i know of that will tell you the size of tools you need. Thanks agian, Jess
