I've been told that mustang hub's will work with my car. I have a 1994 T-bird v8 abs as well as disk brakes all around. I'm replacing my Axels as well as hub's and bearing ect. I wanted to know what do I need to buy if anything to have mustang hub's work on my rear end. As well as what do I need to do.
You are talking about doing a mustang hub swap. That will allow you to use mustang wheels. Yes you can buy cobra hubs for the rear and mustang hubs for the front to do the swap.
Alan
You'll need Mustang wheels, and you'll either need to redrill your stock rotors or buy Mustang rotors, and caliper relocation brackets from Fast Ed N. Check the technical articles for more info.
What year will work on the mustang as well as what do I need to do can I use my old wheels. I'm thinking about doing that instead of buying two new hub's it's a little bit more to do the stang swap by like 20 dollars.
You can redrill your old wheels to 5x4.5 depending on their design; fan blade wheels could be redrilled, 5-spoke Cobras could not. 94-04 Front mustang hubs and 99-04 Cobra rear hubs will work.
