do you know if you have to pull the gas tank down to get the driveshaft out of the way to replace the rear output seal of the trans. When I replaced the trans. I knew it needed to come down but i didnt know if I had to pull it down or not. If I do I will just let it leak for a little while until I can get a lift.
thanks
undo the 4 DS bolts, then the 6 bolts that hold in the IRS, let the pumpkin droop and then youll be able to pull the DS back.
Geek w/Gearhead Complex
bingo. It also helps to drop the exhaust. You don't have to, but it sure as hell helps. I just recently replaced mine :D
