Well, unfortunately there’s A LOT more rust under my car then I thought. Kind of makes me sick really. Most of it seems to be the rear sub frame, diff, LCA’s, and brake lines. There’s also some on the quarter panel under the bumper that’s pretty bad.
Anyway...
Is there any difference between a Mark VIII sub frame and an MN12's? And could I more or less just bolt in the Mark VIII's sub frame with no mods besides spring perch things for the LCA's?
I figure I might as well upgrade a little if I’m going to replace the whole sub frame and get the aluminum diff and arms.
Thanks in advance!
-Dave
Yes, the Mark 8 subframe assembly will bolt directly in place of your stock subframe. The rear subframe in my XR7 is originally from a 94 Mark 8.
-Rod
Where abouts in Maine are you?
I live in Readfield, ME. About 15 min from Augusta.
-Rod
Sweeeet, was hoping it would fit. Now to see if I can find one thats not all rusty and crappy like mine!
double post, sry
