OxmanWI,
Like U S Marine said, start with the inner-uppers... can be done on a set of ramps with a few wrenches/sockets. That might be where the noise is coming from. It'll help rear tire rear wear also. If you're cupping the inside of the rear tires, that's usually the culprit.
The outer knuckle bushings in poly are available here:
Spinning Wheels-SC for $135.00 a set.
For the inner lower control arm bushings, you can get polys from a 1999-2004 IRS Cobra Mustang available here:
Laurel Mountain Mustang for $57.50 a set.
You'll want #6-3llBL... You'll only use the lower bushings, the uppers won't work (the 4 large O.D. bushings in the picture on the site). They're still cheaper than the 4 stock rubber replacements, and really tighten up the rear suspension. While you've got everything apart, you might want new spring isolators - on the same site #6-1709BL. You'll need to order 2 sets though. Some guys say polys ride too rough, but the good news is that they don't deteriorate from ozone and oil like rubber does.
That's what I used on my rebuild, and am quite happy with the way it handles. Bought the car new, and it always felt like the rear end was going to break away first in a hard turn... not anymore! Rides fine as well. Getting ready to rebuild the front end... the second time. Can't figure it out, I've only got 300k+ on the car.
Best of Luck!
That is all...
