1 - 2 of 2 Posts
Is there any downfall to installing the rear sway bar while the tires are not on ramps? Mine was installed with the car on jackstands so the rear suspension was hanging. We didn't have any problem getting the bar in, but I just wonder if we had installed it on ramps if there would be better handling or whatnot.
Thanks
You can't properly tighten the end links with the suspension hanging. I installed the bar with it hanging then just crawled under the car and porperly tightened the end links.
1 - 2 of 2 Posts
