My wife's 97 bird (120k) has a rattle coming from both sides of the rear, especially under low speed deceleration, turns or going over bumps in the road. The rear also felt somewhat "loose" to me, but my other cars have very tight suspension, so my definition of loose may be off.
I got under the car, and if I grabbed the lever arm of the sway bar, I could move it up and down with my hand and re-create the noise. The endlink seemed intact, and although it was dark, it also seemed as if the bushings were in place.
My question is, what is the likely culprit of the looseness? I'll get the car up in a lift this weekend to give it a more thorough inspection, but I was hoping you guys could give me some direction before then, so I'm not chasing parts all weekend. Do you think completely new endlinks? Bushing replacement?
It looks like removing the rear sway is pretty straight forward, but any special tools or knoledge I should have before hand?
Mahalo!
Mahalo!
