Has anyone replaced arms or replaced the bushings only?
Edit:
Never mind. Got it.
Rodney
Fry Rice Specialist
what's the consensus?
I figured it out. I am going to write something up. The whole job was quite easy once done. Looks confusing when you take them off and they fall apart.
Both
~~Hello
One would replace the outer with the Knuckle Bushings. How-ever The inner is Alot harder because it is the Adjuster.
So you would replace the arm for the inner bushing, & Knuckle bushings for the outer.
I would also post how to re enforce this arm. There are pictures of re enforced upper arms around.
Paul
Fry Rice Specialist
i was thinking getting a spare arm from the yard and get it reinforce. how much does the reinforce arm help versus non-reinforce version?
wheelhop?
Fry Rice Specialist
wheelhop?
