drag-aholic
remove the trim down the side of the window (nut inside under small circle cover) then they pop out of a clip then. pop the top trim off. At the bottom remove the slide-on round retainers then it pops off also.
becarefull not to bend the top and bottom trims. they are a thin metal with the black covering and they bend easily.
then i guess you have to cut the window out with a wire. they are glued in
oh yeah unplug the defroster plugs
Thanks. Sounds like an easy enough job.
Any recommendations on what kind of glue to use to to put it back in?
