I was wondering what tool(s) to use to get the retaining nuts off the back of the tail lights so I can disconnect the LED for the tail lights.
Also I read a post about running lean, rough idle, and possible blocked cats. I recently had the 3rd cat and resonator cut off and obviously I have more emissions. Would the emissions cause rough idle. Should this be something I should be concerened about and what could I do to fix it, if there is a problem (besides putting the resonator and 3rd cat back on). Thank you all very much.
