Ok, i've got a problem here, the red plastic vacuum line that goes with the green plastic vacuum line has broken. There's a 3 inch portion missing, and the red line is brittle. There's not a whole lot of the red line sticking out of the loom. I've still got the fitting that goes on the vacuum tree and some of the line off that. What's the best way to try and repair it?
find any kind of small tubing like fuel lines for a weed eater or something similar.
mines melted and they dont make it any more so i gotta find one at a junk yard somewhere
Well, where does the red/green vacuum hoses plug into behind the motor? How hard exactly would it be to remove and replace them. If i went to a junkyard, would i run the risk of having the line break again? Would it better to try and replace the whole red hose, with a piece of rubber hose?
it plugs into the ecv valve (i think id have to check) in the back of the engine. when i go to school monday ill look it up on ALL DATA for you and take some screen shots. 95 Sc bird 3.8?
yeah, 95 SC I managed to fix it by slipping a piece of vacuum line over the red plastic hose. I might have to fix it correctly later though.
