Boost Happy
hey guys i remember when i installed my steeda ud pulleys i think i had a longer bolt just to install the crank pulley and then i had to use the oem one if i am correct but i cant find it now i wanted to swich em and put my stock pulley on i dont think i need that bolt i should be able to install it with the oem bolt right ?thanks
Jurgen
Overkill Fetish Freak
The longer bolt comes with the Steeda kit and is only needed for pulling the Aftermarket pulley onto the crank so you are good to go. Don't forget the RTV in the keyway and tighten the bolt to 115-121 lb-ft.
-Scott
