1 - 13 of 13 Posts
I'm just about to install it on the 90 XR7 with a 4.6L DOHC that I'm putting together. It isn't difficult at all, and it will make it much easier to change the filter.
-Rod
Fry Rice Specialist
i just need the part number to do mine....
any number for me?
Refrigerator Raider Hater
What Scott said. You can use the rubber hose they give and do it for $40, or you can use AN hose and spend $140 after the $40 kit.
Do it right or don't do it at all. If one of those rubber hoses pops off or gets a leak, at the very least you'll have a big mess, and it could send the car out of control. Not to mention your engine seizing from oil starvation.
Overkill Fetish Freak
Picture this.....
I pull up to the chick-Fill-A drive through with a blower sticking out of a hole in my hood. The kid at the drive thru sez... "WOW, What you got in there and Can I hear it?" I rev it and one of those rubber hoses that comes with the "kit" pops off and Cougie turns into the EXXon Valdez with oil all over the place and a flatbed in route. To make matters worse the clean-up kid comes out with a bottle of windex and a rag to clean up the 4 quarts I left on the driveway. Lucky for me this did not go down on the highway or it would have been real ugly.
-Scott
Ugh, what a nightmare Scott.
I've been thinking about the relocation, but now I'll plan better.
Hey, Scott. Where did you locate your filter mount?
I installed a kit also. It's just the basic $40 one from Summit though. It sure does make oil changes a helluva lot easier though! I did have a rubber line blow off though on my way home one night :eek:. It was my fault though, I had kinda stripped one of those hose clamps and it finally blew before I was unlazy enough to put a new one on. But now I have a new one on and it hasn't given me any trouble yet. I mounted mine under the battery tray also, but it's bolted to the "frame" horizontally, not directely bolted to the underside of the battery tray. One day I will do it Frankencougie style with all them fancy fittin's :D
I
Guest
DMcBrideBoston said:
This does not seem like a expensive or complicated project.....Am I misguided somehow?
Pros /Cons?
You are talking about the Gagfish tutorial, right?
I've done it, but take Scott's advice when it comes to the hoses. Buy the $40 kit out of the Summit catalog, and once you get it measure out the amount of AN hose you would need given your setup location, and buy yourself the AN. I put in the kit with little difficulty (hard to believe considering my lack of skill, but yes, it's true), waited about a month, and then upgraded the rubber hoses to AN lines. Pricey - yes. But the peace of mind you'll have knowing that the hose is not going to blow or tear is immeasurable. Good luck.
Illinois Chapter Director
I worked on a kit right before taking my car to the dyno. I bought push lok and braided with all the 8AN fittings. I busted a knuckle on a vice the week before so the push-lok got the nod(not like anyone cares).
When I first turned the key that was the first thing to leak and I didn't have time to figure out where the leak was coming from. With the big bars it was a pita putting it in, but I never do things right the first time....so I may try again in the near future.
If anyone is interested in installing one, I have all the fittings for the TD kit and I'll sell the filter mount too. Let me know.
I have stuff for braided and stuff for push-lok here somewhere.
1 - 13 of 13 Posts
